Install and connect oil cooler valve controller in panel insert.
Connect LED indicator lights.
Install fuel transfer pump switch in panel insert.
Secure panel insert using 6-32 torx screws.
Install the throttle quadrant console and insert using 6-32 torx screws.
Next, I began installing the essential bus circuit breaker panel. The fuel pump power wires from the relay were connected to the respective circuit breaker. The fuel pump motor wires and the fuel pump monitor wires were then terminated with a ring terminal and connected to the respective circuit breaker. The monitor wire connect to the EFII controller and provide a sense voltage while the pump is running. This generates an indication on the controller screen of which pump is running.
