Route and connect oil cooler valve power to aux fuse block.
Route and connect oil cooler valve ground to aircraft ground.
Route and connect fuel pump mode switch wiring to essential bus power.
Route and connect fuel pump relay power to essential bus.
Route and connect GEA24 volts 1 input to essential power bus. This will allow the essential bus voltage to be monitored at all times.
Connect #10 wire to essential power bus post.
Label and install main and essential bus covers.
Route and bundle fuel pump wiring consisting of relay power, fuel pump +12v, and EFII controller inputs for pump 1 and pump 2. This will allow a visual indication of which pump is powered on the controller display.
