Bobs Ten
Date:  12-27-2019
Number of Hours:  2.10
Brief Description:  Install Instrument Panel
1330 - 1536
Continue wiring.
Route and connect start annuciator wire to VPX pin J2-11. This wire is connected to the I terminal of the start contactor. Connection was made using a parallel twist and solder joint.
The wire bundle passing through the firewall was then bundled and tie wrapped.
Verify injector switch and ignition switch wiring for correct position, ie when switch is in the #1 position, the #2 control wire is grounded, disabling the #2 injector control or #2 ignition.
Route and connect injector controll wires to main harness injector control switch.
Route and connect ignition P lead wires to main harness switches.
Wires were connected using parallel twist and solder.
