Today was spent designing and fabricating a doubler and support for the GMU22 mount.
According to the Garmin manual, this unitr must be mounted to a rigid support; mounting it in the standard RV-10 location did not comply. The standard location is on the bulkhead aft of the baggage area bulkhead. In this location, the bulkhead is fairly flexible. I opted to fabricate a doubler with a flange bent into it for stiffness. The doubler was fabricated from 040 sheet.
The doubler was clecoed to the bulkhead and mount to check it's rigidity...it was better but still not satisfactory.
