Bobs Ten
Date:  11-8-2019
Number of Hours:  1.90
Brief Description:  Install Instrument Panel
1530 - 1724
Route and connect door reed switch wiring. The G3x has the ability to register a door open warning with associated logic. I determined that a relay set was NOT required, as I will not have discrete door lights, only the EFIS caution and warnings. The schematic that SteinAir sent verifies this. I connected each reed switch on the left door in series, and each reed switch on the right door in series. This will require BOTH switches to be closed (door closed) to provide a ground path, and extinguish the door open warning.
The switch wires were extended and connected as necessary.
Operationally verified operation of the door warning switches.
I then installed the RGB LEDs in the aux fuel pump panel. As previously detailed, these lights will turn green when the associated pump is on and red when the pump is off (switch is on and timer has expired). The lights will be off when power is removed from the system by turning the switch off.
