Remove and replace several Adel clamps used for wire guides, to larger sizes.
Connect appropriate wires to aux fuse block.
Route and connect appropriate ground wires to ground block.
Organize wire bundles again.
Prepare aux fuse block power supply lines with Faston ring terminal.
Prepare #6 main VPX power supply. This wire was routed and supported with Adel clamps. A #6 x 1/4" terminal lug was installed using the hydraulic crimper. It was then protected using DW heat shrink.
The #6 cable and the two #14 wires were then secured to the VPX with the included locknut.
The VPX was positioned and measured from a reference line to verify clearance with the A/P control head connector.
