Bobs Ten
Date:  10-6-2019
Number of Hours:  7.50
Brief Description:  Install Instrument Panel, Avionics Wiring
1130 - 1700
Continue fabricating transponder rack. Standard techniques were used and the cantilever supports were riveted to the rack shelf using LP4-3 and CS4-4 blind rivets with support washers.
Fit was verified...
Remove ER tank.
Remove HID ballast and adjustment plate.
Reinstall landing light mount and lense.
Reinstall ER tank.
Pull wiring for wingtip and landing lights as previously detailed.
Install aileron electric trim servo. In order to accomplish this, a short wire harness was fabricated from appropriate wire. We installed a D-Sub 9 pin female connector to mate with the trim servo wiring. Note: Looking AT the male pins, the wiring is white - blue - white on top, and green - orange on the bottom.
Once the wiring was complete, we connected the aileron push rod springs to the aileron trim servo. The servo and inspection plate wash then installed using the specified hardware.
Moverment of the pushrod was verified.
