Today I recieved the correct sized tri color LEDs for the Aux Fuel Pump indicators. I eneded up rewiring the timer relays because these LED have a common V+ instead of V-. It was not a big deal but did require minor changes.
Next I installed the 10 position through mount fuse block in the previously fabricated shelf. Standard techniques and nut plates were used. Fuse block was mounted to shelf with #8 hardware.
The shelf was installed to verify fit and clearances.
