Bobs Ten
RV-10
Doors
2-15-2016
Door Hinge Pocket Covers
1418 - 1554 1836 - 2000
Sand all covers and fillets to final contour using sander and s/p.
Apply final coat of epoxy/micro to fill remainig low areas.
The Bansbach gas struts arrived. Look good except the machined end was 10 mm thick and the drilled hole, 8.2 mm.
Using the Smithy, I machined the thickness of the two rod ends to .375, which is the correct thickness for the billet brackets.
Using drill press, I enlarged the 8.2 mm hole to .375 to facilitate the use of an aluminum bushing.
Fabricated two aluminum bushings to fit the ends from .375 thickwalled tubing. The tubing ID is appropriate for an AN4 bolt.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
