Bobs Ten
RV-10
Doors
2-8-2016
Fabricate Door Hinge Pocket Covers
1630 - 1900
Continue with pocket cover fabrication.
As was detailed previously, the covers were cut to fit, bonding surfaces roughed with 60 s/p, and seams were glued with CYA.
All door surfaces were roughed up for bonding.
A cover was also made for the notch cut in the door bottom for the third latch.
Epoxy was mixed and all surfaces wet out.
The seams were reinforced with 9 oz cloth.
Added cabo to remaining epoxy, applied to all bonding surfaces.
Covers were then clecoed in place and excess epoxy removed.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
