Bobs Ten
RV-10
Doors
2-4-2016
Gas Strut Installation
1506 - 1736
Position the strut attach brackets against door and clamp.
Verify location of brackets.
Match drill brackets and door using #30 drill, cleco as drilled.
Remove clecos.
I decided to fill the area around the door hinges in the cabin top pockets with epoxy to prevent water and debris from collecting there.
Remove both doors from fuselage.
Cover all hinges with packing tape to provide for mold release.
Rough cabin top pockets using 80 s/p.
Install doors on fuselage.
Mix epoxy and apply a wet out coat on the area around the hinges.
Mix flox/micro/cabo into epoxy.
Apply epoxy around all hinges, remove excess epoxy.
Once epoxy is cured, I will fabricate SS covers for the hinges.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
