Bobs Ten
RV-10
Doors
1-31-2016
Right Side Door Handle
1548 - 1906
Using Vans, Planearound, and Aerosport instructions, install handle mechanism in right door.
Temporarily install door pins.
Install pin blocks.
Mark pins to be cut to length.
Remove pin blocks, pins.
Cut and polish pins then thread ends.
Install pins, pin blocks, and previously made pointed pin ends.
Install door on fuselage.
Position door in fuselage and mark the door channels using the door handle mechanism to drive the pointed pins into the fiberglass channels.
Drill door channels using #30 drill, increasing to 5/16".
Verify fit and operation of door mechanism.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
