Remove door from fuselage. The packing tape worked pretty well for preventing the door from bonding to the fuselage.
Remove packing tape from fuselage. This proved to be more challenging than I thought from the aluminum fuselage as the tape tore in several places leaving smaller pieces. After a few minutes, all tape was removed.
All clecos removed from window opening.
Using RO sander, knocked off the sharp epoxy edges.
Using 2 clecos, cleco the door to the fuselage to verify fit. Door fits nicely to fuselage and all bonds appear to be good. Will check again as flanges are trimmed to final dimensions.
