Bobs Ten
RV-10
Doors
10-29-2015
45-03.1>3, 45-04.1
Prepare Doors for Bonding
1424 - 1518 1548 - 1624
Mark open rivet holes per plans.
Cleco door panels to fuselage using forward and aft index holes and lower window index holes.
Using procedure in plans mark doors for open rivet holes.
Drill door panels for open rivet holes using #40 drill, start in center, alternate forward and aft, cleco as drilled.
Noted one rivet was installed that should have been left open. Drilled rivet out, marked door panels and drilled hole.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
