Bobs Ten
RV-10
Wing Attach
7-25-2015
44-6.1>3
Install Lower Wing Root Fairings
1418 - 1718
Check flap pushrod adjustment. Loctie and secure jam nuts, 4x.
Final drill lower root fairings using #19 drill.
Debur all holes.
Dimple all holes to accept #8 screw using DRDT.
Cleco fairng support to fuselage, 2x.
Cleco right fairing to lower surface of wing.
The inboard edge of the fairing at the leading edge needed to be trimmed.
Trim fairing using file, drum sander, s/b wheel to yield a nominal 1/16" gap between fuselage and fairing.
Install several AN509-8R8 screws in fairing.
Match drill remaining holes using #40 drill, cleco as drilled.
Final drill holes using #19 drill, cleco as drilled.
Repeat for left fairing.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
