Bobs Ten
RV-10
Wing Attach
6-10-2015
Fabricate Flap Pushrods
1524 - 1630
Trim VA-256 pushrods per plan using bandsaw, bench grinder, 2x.
Clean threads using 1/4 x 28 tap, 4x.
Debur and smooth ends of pushrod using s/b wheel.
Install jam nuts on rod end bearings, 4x.
Measure threaded end of bearing and set jam nut to specified length.
Install bearings in pushrod.
Verify nominal specified length.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
