Bobs Ten
RV-10
Wing Attach
4-11-2015
Install Wing Root Fairing Supports
1642 - 1824
Peel vinyl coating from inside of wing root fairings in preparation for priming.
Debur and smooth all edges of fairings using s/b wheel.
Drill bushing hole in F-1006 bulkhead for conduit, debur, insert snap bushing.
Flute the vertical flange of the support pieces, where necessary, to match holes in left fuselage side skin.
Cleco fairing supports to fuselage, every other hole.
Final drill open holes using #30 drill, cleco as drilled.
Remove previously installed clecos and final drill remaining holes using #30 drill.
Repeat for right side.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
