Bobs Ten
RV-10
Cabin Top
8-24-2018
Install Windows
1515 - 1615 1700 - 1800
Install windows in door assemblies.
We found that a good method was the following:
Apply a bead of adhesive.
Install window.
Set corner clamps.
Press window into adhesive.
Wipe away excess adhesive on the out side, clamping as necessary.
On inside, wipe away excess adhesive.
Remove masking tape.
Clean and smooth fillet using a small clean rag and DT870 reducer.
Back to outside, remove clamps a couple at a time, clean and smooth fillet.
Remove tape.
Reinstall clamps a couple at a time.
Total elapsed time from glue open to finish, 60 minutes per window.
Clamps will remain until full cure is achieved...24 hours.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
