Bobs Ten
Date:  3-15-2015
Number of Hours:  1.00
Brief Description:  Prep cabin Top Hinge Pockets
1600 - 1700
Tried to clean up the interior hinge pockets on the cabin top. The fiberglass in these pockets was very uneven. As the nuts for the hinge attach bolts will be bearing on these areas, I decided to make them more even and flat. Some sanding was done but I decided to lay up a thin coat of epoxy/Flox and smooth this layer. This should give a substantially flatter surface for the nuts and washers to bear on.
Definitely unimpressed with Van's fiberglass work...
