Bobs Ten
Date: 1-5-2015
Number of Hours: 1.80
Manual Reference: 43-6.1>4, 43-7.1>7
Brief Description: Install Cabin Top
1630 - 1818
Cleco cabin top and top skin in position.
Clamp cabin top per plans, match drill F-1005 to cabin top using #30 drill, cleco as drilled, 14x.
Final drill holes using #12 drill, cleco as drilled, 14x.
Clamp cabin top per plans, match dril F-1042 to cabin top using #30 drill, 10x.
Bending F-1042 per plans, cleco F-1042-F to F-1042, final drill using #30 drill, cleco as drilled, 12x.
Match drill remaing holes in F-1042 to cabin top using #30 drill, cleco as drilled, 6x.
Clamp cabin top botton channel to fuselage deck per plans.
Transfer hole locations from fuselage.
Match drill bottom channel to deck using #30 drill, cleco as drilled, 14x.
Final drill holes using #19 drill, cleco as drilled, 14x.
