Bobs Ten
RV-10
Cabin Top
1-4-2015
Match Drill Cabin Top
1236 - 1336
Match drill cabin top flange to fuselage skins, using #30 drill, cleco as drilled.
Two small areas of the cabin top flange need to be trimmed, when top is removed, to provide nominal clearance.
Verify cabin top fit to fuselage. Minor adjustment needed on right side. Re clamp cabin top in position.
Match drill holes in cabin top from F-1005 channels using 12" long #30 drill, cleco as drilled, 8x.
Top of channels need to be trimmed prior to match drilling, necessitating removal of cabin top.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
