Bobs Ten
RV-10
Empennage Fairings
11-28-2014
12-3.5>8
HS Tip Fairing
1342 - 1500
File right HS tip fairing to provide 7/32" nominal clearance with elevator counter balance.
Remove tip fairings.
Remove temporary rib.
Cover outside of rib with Tyvec tape to prevent epoxy from bonding to rib.
Install temporary rib using hot glue.
Mix epoxy and wet out two pieces of 9 oz cloth.
Apply wetted cloth over temporary rib, ensuring edge of fairing was completely wet.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
