Bobs Ten
Date:  3-11-2018
Number of Hours:  1.00
Brief Description:  Install Prop Governor Bracket, Cables
1524 - 1624
Today I installed the prop governor bracket.
Per the Governor instructions, the fine adjustment was rotated CCW to improve fit with low RPM stop.
The bracket was installed by removing three cap screws. I will replace these cap screws with 8-32 x 1/2 to compensate for thickness of the bracket.
The stock arm was replaced with the optional longer arm per instructions.
Cable length were determined and are to be ordered. It looks like a 55" throttle cable and the stock prop cable of 70.5".
