Fabricate baffle joining clips. I had previously fabricated the clips per vans plans but decided to go another route. I fabricated the clips such that they could be attached using #6 flush screws. This will make removing the baffles substantially easier should the need arise. I also decided to add stiffening flanges on the two larger clips.
This fabrication was completed using standard techniques.
