Bobs Ten
RV-10
Seat Backs
8-24-2014
42-3.2>5
Fabricate Seat Backs
1324 - 1506
Clamp seat back angles to seat backs.
Match drill angles using #30 drill, cleco as drilled.
Layout and drill 063 top angle using 1/8" drill.
File and smooth angle apex to nest in seat back using vixen file and s/b wheel.
Clamp top angle to seat back.
Match drill seat back using #30 drill.
Remove specified eyelet from upper hinge sections.
Clamp lower angle and upper hinge section to seat back.
Match drill using #30 drill, cleco as drilled.
Clamp top flange to upper angle.
Layout and drill for flush rivets.
Repeat for other seat back.
Remove all clecos.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
