Finalized the size of the elevator down stop. I have 19 degrees down elevator and the stick grip is about 3/16" from the honeywell switches. Elevator stop was reinstalled and torqued.
Worked on the elevator trim. Had to call Vans as the center of the RAC servo does not correspond with neutral trim. Using 35 degree down tab as per the plans, neutral trim occurs approximately 30% from full down trim. I will see if the neutral line in the EFIS can be changed. As the RV-10 needs a substantial amount of up trim, according to Vans, this is normal.
Routed wiring for taxi lights.
Fitted wing root fairings. A template was made for the extra riblet that I will fabricate to suport the fairing where material has been remove for the light lense.
