Installed vertical stab front spar bolt, torqued and pinned with specified hardware. This was an AN4-5 bolt that I did not have. It was sourced and the temporary bolt replaced.
Worked on elevator down stop. I had to fabricate another due to removing too much material on the previous one. It's length greatly affects the amount of down elevator available, and the amount of intereference of the stick and panel. It looks like 11/16" will yield 20 degrees down elevator and about 3/16" clearance on the panel switches.
Unfortunately, the work session was cut short due to a thunderstorm causing loss of power at the airport.
I also cut the hole in the wing root fairing to verify size and location with respect to the taxi light assembly. I needed to enlarge the lower part of the hole to allow for adjustment of the light. The second fairing was then cut in a similar fashion.
I will use the Duckworks lenses to make the plexiglass lenses for the taxi lights.
