Bobs Ten
Date:  7-4-2020
Number of Hours:  3.00
Brief Description:  Fabricate Taxi Light Mounts
1530 - 1830
Using the information from the first iteration of taxi light mounts, I fabricated version 2. This version will easily mount to the aircraft and will be on axis with the leading edge. The last version would have required an off axis slot in the wing root fairing.
Standard techniques were used to fabricate the mounts from aluminum sheet and angle.
The new mount will allow easy adjustment for aiming the lights,
Pictures are on the camera...at the hangar. I will update this entry tomorrow with the pictures.
