Bobs Ten
Date:  7-2-2020
Manual Reference:  44-All
Brief Description:  Install Flaps
Installed flaps.
I was short hardware, so the flaps will be completed when hardware arrives.
Flaps were check for operation. As it turns out, the VPX control needs to be reversed. I powered up the system, connected the computer to the VPX and made the change. System was rebooted and works normally.
Worked on the control stick/down elevator issue. I will need to take the digital level to verify but I think a 5 degree bushing and a small reduction in down elevator travel will solve the problem. This will be a project for tomorrow.
I fabricated a taxi light mount today to test. The test showed several issues which will be fixed in iteration 2.
Routed and secured wire bundles in right wing root.
