The wing bolts were then addressed. Unfortunately, it was apparent that several of the nuts were bottoming on the bolt threads instead of the spar surface. A call to vans was made and they confirmed that an additional washer could be used. Unfortunately, I had to order the AN960-916 washers from ACS, so the wing bolts will be finished when they arrive.
