The complete cowl was installed with the skybolt flanges still clecoed.
At this time, the split gap was finished using permagrit tools. This required installation and removqal of the cowl several times, as well as the flanges. The split gap now has a nominal gap of 3/32" along the entire line.
The cowl was removed and flanges clecoed every other hole.
The flanges were then riveted using a p-squeezer.
The studs were installed in the grommets and the grommets into the cowl. O rings were used as retainers to ease removal for painting.
The cowl halves were joined and the receptacles adjusted. The pins were then pulled and the receptacles locked at the correct depth.
Next, the remaing nut plates were installed in the nose of the cowl at the inlets and just outside of the spinner. These will be #8 screws.
