Bobs Ten
RV-10
Modify Cowl
1600 - 1854
Today was a good day. I drilled the required holes for the skybolt studs. All holes were deburred and smoothed. Each hole was test fit with a grommet.
I verified my cut line several times.
Using a Fein Multimaster, I carefully cut the cowl. Once separated, the edges were trued and smoothed.
The skybolt flanges were then assembled per the instruction using a p-squeezer.
The flanges were then clecoed to the cowl.
The left cowl was easily attached.
The fit was verified and no skybolt receptacle caused interference.
The right cowl was installed easily, and the bottom skybolts were secured.
I am unbelievably happy with the result! The cowl feels as it was never cut, very secure.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
