I worked on finishing the wingtip lenses and lights.
While working on the right tip, I noticed that the 032 aluminum sheet was deforming under the pressure of the lifght adjustment springs. I decided to fabricate new mount plates from 063. This was fairly simple by clamping the original to the new sheet and duplicating it. This was accomplished for both sides.
I installed the nut plates for the lense retention screws using SS flush blind rivets.
Installed the new mount plate and lense to verify fit.
The work on the left tip then began. I noted that the Cee Bailey lense cover was almost perfect from the start.
