This evening I fabricated the two taxi light assemblies. These are the FlyLeds doubles. They will be mounted at each wing root. Fabrication followed the manufacturers instructions. Light were operationally checked...and they are bright.
Installed right wingtip recog light. Also a FlyLed single.
Worked on fitting the right wingtip lense. This is a Cee Bailey lense. Surprised at the amount of fitting necessary; substantially more than the windows but still not more than 3/16". Again, it is annoying that the molded wingtip lense joggle is not anywhere near consistent. It ranges from about 1/16" to a full 1/8", making lense fitting challenging. Got the rough fit done and will finish it up tomorrow and install the nut plates.
