I installed the aft right and baggage right panels today. Procedure was the same as the right side and previously detailed. The right side baggage actually has a full panel but install was the same as all other panels.
Time was spent with minor fitting and trimming, installing nut plates and a rivnut in the baggage sidewall.
The second session today, I began to install the rear seat vents per the instructions. The panels were cut for the vents on the inside of the scribe lines and then slowly filed to final dimension. The result is a snug fitting vent in the the panel.
