Bobs Ten
Date:  5-26-2020
Brief Description:  Interior Panels
2000 - 2200
Today I worked on installing the aft interior panels.
These were much easier than the front panels. Minor sanding yielded a very good fit. Nut plates were installed per the instructions using standard techniques. I did use a laser level to locate the aft screws and this method works really well.
Once the nut plates were installed, the panel was installed with 6-32 hardware and the fit was verified.
