Bobs Ten
Date:  5-15-2020
Number of Hours:  2.40
Brief Description:  Install Charge/Jump Ports in Baggage Bulkhead
1918 - 2142
Today I finalized the design and location for the charge/jump ports.
Begin fabricating port mount bracket. Standard techniques were used.
The bulkhead fittings will allow the EC5 connectors to sit just behind the baggage bulkhead. They will be hidden with a small cover secured with 2 skybolt fasteners. This will prevent dust, dirt, and damage to the connectors. In the event charging or a jump start is required, the cover panel can be easily removed to expose the ports. The charge leads or jump pack will then be easily connected.
The brakes have not leaked...
