Bobs Ten
Date:  4-25-2020
Number of Hours:  6.50
Brief Description:  Heat Valve Controllers
1230 - 1600 1830 - 2130
I finished the heat valve and fan rewiring.
The LAC boards were wired and installed in the aluminum enclosure. The power, ground, and both pot wires were terminated using appropriate Deutsch connectors.
The overhead console wiring was organized and terminated using Deutsch connectors. All connectors were labeled. These terminations occurred between the firewall and subpanel, thanks to the previously installed access panels.
Each connector was then checked for circuit logic using a DMM.
The LAC board enclosure was then secured to the subpanel using 3M Extreme fastener tape.
All connections were then secured and the overhead was powered. The fans were check for normal operation. The aft vent controller was checked for operation. The heat valve controllers were also tested for proper operation.
NOTE: The fans and aft vent control draw power from the overhead circuit. The heat valve controllers draw power from another dedicated circuit. Both circuits are fused on the aux panel.
Wires were bundled and tie wrapped.
Tomorrow, I will close the overhead panel...
