Finish installation of the forward left interior panel.
Holes were located and drilled for nut plates at the forward and middle positions. Nut plates were installed using standard techniques.
The top aft holes were match drilled in the panel using a strap duplicator.
The aft lower hole was located and drilled for a sheet metal screw. This was necessary to facilitated removal of the panel and the forward seat base skin.
The panel was installed with clecos to verify fit and clearances.
