Bobs Ten
RV-10
Install Instrument Panel
1400 - 1700
Today I completed the ELT installation.
All wiring to the activation beeper was completed and secured. The beeper is a
Mallory PK-20A35EWQ
The beeper was attached to the fuselage side skin using VHB tape. Wiring was completed using a Deutsch connector.
The beeper was operationally tested.
Next, I installed the transponder antenna double using standard techniques.
The antenna was then temporarily installed to determine RG400 length. The cable will be completed when the BNC connector arrives.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
