Bobs Ten
RV-10
Install Instrument Panel
1854 - 2054
Today I populated the DB25 connector for the passenger headsets and music input. This connector is labeled CONN 2.
Wire lengths were determined.
Using standard techniques, shield wires were installed on each cable using solder sleeves.
Wires were then stripped and female receptacles installed using AFM8 crimper.
The DB25 was then populated using the previously created pin out diagram.
The wire bundle was then wrapped with SVT and clamp installed.
The backshell was assembled and additional SVT installed for strain relief.
Wire bundles were temporarily tie wrapped for organization.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
