Bobs Ten
RV-10
Install Instrument Panel
1300 - 1500
Continue with tunnel console wiring.
The first task today was to install the rudder trim pot into the console. Wires were soldered to the pot as follows:
White = V+
White/Orange = signal (Vwiper)
White/Blue = V-
A Deutsch connector was installed on the pigtail end. This will facilitate easy removal of the console for future maintenance.
Standard techniques wered used for wiring. The pot was then installed in the console. The rudder trim knob from Aerosport was installed on the pot.
Next, the console was drilled for the seat heater control switches using a unibit. The holes were deburred and the switches were installed.
A small amount of E6000 adhesive was used to prevent rotation of the switches or pot.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
