Bobs Ten
RV-10
Install Instrument Panel
1512 - 1712
Today I worked on the tunnel.
Clean out and remove dust from mid tunnel section.
I added a spot of E6000 adhesive to the flap actuator motor housing to secure the flap wiring connectors. I then tie wrapped them into position.
Install the forward mid section of the tunnel cover. Install the wiring conduit pass through doubler.
Install aft mid section of the tunnell cover.
Final installation will be complete with the center console installation.
Install USB ports in the console inserts.
Verify all console wiring routing for clearance and any interference with the console. All clearances are satisfactory.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
