First task today was to install the 3 pin Deutsch connectors on the aileron trim motor wires that carry through the fuselage from the roll servo to the aileron trim servo. Standard techniques were used.
Next, I began final bundling of the right side fuselage wiring. Some wires were rerouted. Small bundles were tie wrapped to facilitate installation of the Aerosport side panels.
The wing lighting wires and fuel pump wire was routed throught the previously installed grommet. Bundles were then tie wrapped to yield neat wiring.
