Wiring of the aux fuel pump switch was comleted today.
The original switch was removed and wires labeled.
The fuel pump wires were connected to the wires from the timer relays, as previously detailed.
Deutsch connectors were installed on the appropriate wiring from the timer relays to match the connectors on the indicators.
All wires were bundled and included in the harness branch wiring.
The CF panel was installed to verify fit and correct wire lengths. Minor changes were completed.
Using a power supply, the aux pump switch and timer relay logic was verified. I currently have the timers set at 16 seconds to verify operation. Actual times will be determined using full tanks but should be around 24 minutes.
