Route and connect master warning and master caution discrete wiring. Once routed, the wires were joined using a parallel twist joint and then soldered and protected with double wall heat shrink.
Next, the discrete wires for left door, right door, and pitot warning were routed. The wires were then teminated using appropriate sockets for the existing Molex connector. The sockets were crimped and soldered, then installed in to the Molex connector. Wiring was then tie wrapped.
