Bobs Ten
Date:  12-16-2019
Number of Hours:  3.00
Brief Description:  Install Instrument Panel
1648 - 1948
Route and connect USB supply wire to aux fuse block.
Begin connecting avionics ground wires to forest of tabs. First I needed to shorten three previously connected grounds. I then organized the ground wire bundle into individual faston connectors...there are sixteen connectors, each with multiple wires.
Installed an Adel clamp to guide and secure ground wires from the harness trunk.
Begin shortening the ground wires, one connector at a time. New lengths were determined, wires shortened, new faston connector installed. I completed four of the sixteen connectors.
