Install Steinair wire harness! This is going to take some time to sort out. It appears that almost all of the connections will reach the required LRUs.
I began by positioning the trunk of the harness in it's approximate location. I then started to route and temporarily connect the LRUs to their respective wiring. It was necessary to remove some of the lacing on the right side of the aircraft to create additional length on the transponder harness. It should be long enough to reach now.
The PFD and MFD wiring will reach, as well as the GSU25 and GAD29.
The GDL51R looks to be very close, and the GEA24 harness will need an extension.
I started dividing up the wild wire coils and placing them in their approximate locations.
