I required another conduit to route the GMU22, Pitch, and Yaw wiring. It is truly annoying that the RV-10 is lacking in acceptable areas to route wiring, and with a full IFR airplane, there is a ton of it.
Another conduit location was located and installed.
I spent the better part of an hour attempting to remove a VPX pin from the J8 connector. It would not release no matter what I tried. It was the last pin that needed to be changed, and of course, the J8 connector failed. Sooo, I unpinned all the other 7 wires from the connector without any problem and I will have to get another connector. Very frustrating...time to stop for today.
