Bobs Ten
Date:  10-31-2019
Brief Description:  Install Instrument Panel
1600 - 1800
Today I had to reroute a small wiring harness related to the Bus Manager. This should have been an easy task, however, the fuel pressure wire pulled out of it's molex pin and I was unable to remove the pin from the housing. This required populating a new molex connector to duplicate the original. Luckily, I had a spare housing and enough pins to complete the task. All pins are now crimped and soldered.
Remove and replace Bus Manager control connector.
Reinstall all affected wiring.
